Flashes
Flash problems
<blockquote data-quote="WayneF" data-source="post: 473513" data-attributes="member: 12496"><p>OK, sorry, then I misunderstood what you meant.</p><p></p><p>Well, the radio triggers are manual flash, which always has to be adjusted. TTL is at least a fairly close starting point. <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p><p></p><p>My experience is that the Commander always needs a little +EV compensation. It does TTL BL mode, which is also the SB-700 default mode. I suspect that underexposure is an intentional safeguard (balancing with ambient or a second flash), but to me, speaking indoor flash, it seems that the Commander or a TTL BL hot shoe flash may normally always need maybe +2/3 EV compensation, maybe +1 EV compensation (as compared to actual TTL mode, which older flashes like SB-600 or SB-800 offer). We do what we have to do of course, but I just routinely and automatically include that +EV compensation that in my initial settings, then it always seems pretty good.</p></blockquote><p></p>
[QUOTE="WayneF, post: 473513, member: 12496"] OK, sorry, then I misunderstood what you meant. Well, the radio triggers are manual flash, which always has to be adjusted. TTL is at least a fairly close starting point. :) My experience is that the Commander always needs a little +EV compensation. It does TTL BL mode, which is also the SB-700 default mode. I suspect that underexposure is an intentional safeguard (balancing with ambient or a second flash), but to me, speaking indoor flash, it seems that the Commander or a TTL BL hot shoe flash may normally always need maybe +2/3 EV compensation, maybe +1 EV compensation (as compared to actual TTL mode, which older flashes like SB-600 or SB-800 offer). We do what we have to do of course, but I just routinely and automatically include that +EV compensation that in my initial settings, then it always seems pretty good. [/QUOTE]
Flashes
Flash problems
