Flashes
Flash help
<blockquote data-quote="Mfrankfort" data-source="post: 194202" data-attributes="member: 12881"><p>TTL is the camera's attempt at sending out the right amount of light through the flash. Sometimes it's not right, and you can't dial in specific power (per se) in TTL, like in M, so you can use Flash compensation to give it a little more power, or a little less power. Sometimes TTL gives weird results depending on the ambient light available, or the scene.</p></blockquote><p></p>
[QUOTE="Mfrankfort, post: 194202, member: 12881"] TTL is the camera's attempt at sending out the right amount of light through the flash. Sometimes it's not right, and you can't dial in specific power (per se) in TTL, like in M, so you can use Flash compensation to give it a little more power, or a little less power. Sometimes TTL gives weird results depending on the ambient light available, or the scene. [/QUOTE]
Flashes
Flash help
