Wedding
First Wedding, Help needed!
<blockquote data-quote="Targarien" data-source="post: 763782" data-attributes="member: 49276"><p>If you are at your first wedding, you should be prepared for everything and make sure everything is going to work perfectly. I would suggest working besides some ...before seeing how a wedding should go. If you've already did that, it's time for you to charge your batteries, prepare your cards and let your imagination fly high. The possibilities are endless when it comes to this domain and there is nothing that can stop you. Just be careful and make sure that you are going to capture every important moment</p></blockquote><p></p>
[QUOTE="Targarien, post: 763782, member: 49276"] If you are at your first wedding, you should be prepared for everything and make sure everything is going to work perfectly. I would suggest working besides some ...before seeing how a wedding should go. If you've already did that, it's time for you to charge your batteries, prepare your cards and let your imagination fly high. The possibilities are endless when it comes to this domain and there is nothing that can stop you. Just be careful and make sure that you are going to capture every important moment [/QUOTE]
Wedding
