Photography Q&A
Difficult Exposure - Sunlight from Window on Model in Room
<blockquote data-quote="aroy" data-source="post: 552614" data-attributes="member: 16090"><p>This is a classical situation where you would benefit with HDR as the dynamic range between the highlights and the shadows is very high.</p><p></p><p>I would use spot metering for the brightest portion without any exposure compensation. Then recovered shadows. There is enough light to use ISO 400 even 100. Even with D3300 which has a lower DR, you can recover shadows from such shots if you shoot at ISO 100. Here is what you can do with D3300 file. The D750 would have less noise and more DR so darker areas will be cleaner. Spot metering on the brightest area.</p><p></p><p>[ATTACH]209059[/ATTACH]</p><p>Out of Camera</p><p></p><p>[ATTACH]209060[/ATTACH]</p><p>After processing</p></blockquote><p></p>
[QUOTE="aroy, post: 552614, member: 16090"] This is a classical situation where you would benefit with HDR as the dynamic range between the highlights and the shadows is very high. I would use spot metering for the brightest portion without any exposure compensation. Then recovered shadows. There is enough light to use ISO 400 even 100. Even with D3300 which has a lower DR, you can recover shadows from such shots if you shoot at ISO 100. Here is what you can do with D3300 file. The D750 would have less noise and more DR so darker areas will be cleaner. Spot metering on the brightest area. [ATTACH=CONFIG]209059._xfImport[/ATTACH] Out of Camera [ATTACH=CONFIG]209060._xfImport[/ATTACH] After processing [/QUOTE]
Photography Q&A
