Nikon DSLR Cameras
D5
D5 Shutter speed challenge
<blockquote data-quote="BF Hammer" data-source="post: 775581" data-attributes="member: 48483"><p>You are right, the shutter speed wheel will go from 30sec to "Bulb" to the final position which is the flash synch shutter setting. I work in the 25sec and bulb range enough that I should have remembered that. But then I also assumed you tried spinning the wheel in both directions.</p></blockquote><p></p>
[QUOTE="BF Hammer, post: 775581, member: 48483"] You are right, the shutter speed wheel will go from 30sec to "Bulb" to the final position which is the flash synch shutter setting. I work in the 25sec and bulb range enough that I should have remembered that. But then I also assumed you tried spinning the wheel in both directions. [/QUOTE]
Nikon DSLR Cameras
D5
