Nikon DSLR Cameras
D3300
D3300 and WU1 wireless adapter
<blockquote data-quote="dachshund" data-source="post: 664156" data-attributes="member: 41851"><p>When using the D3300 with the WU1 wireless adapter you must set the “wireless connections” in the setup menu to “on”. When not in use and the adapter removed, will there be battery drain if this option is not turned off. I’ve read that this option is a battery hog but don’t know if this means only if the adapter is left plugged in.</p></blockquote><p></p>
[QUOTE="dachshund, post: 664156, member: 41851"] When using the D3300 with the WU1 wireless adapter you must set the “wireless connections” in the setup menu to “on”. When not in use and the adapter removed, will there be battery drain if this option is not turned off. I’ve read that this option is a battery hog but don’t know if this means only if the adapter is left plugged in. [/QUOTE]
Nikon DSLR Cameras
D3300
