Flashes
Continuous Shooting with External Flash - D5100
<blockquote data-quote="WayneF" data-source="post: 237382" data-attributes="member: 12496"><p>It is just the internal flash that cannot... I think the SB-700 should do repetitive flashes, if not going too fast to allow recycle.</p><p></p><p>For example, the SB-800 has a repeating mode with this rate/power chart in the manual.</p><p></p><p><img src="http://www.scantips.com/g2/repeat.jpg" alt="" class="fr-fic fr-dii fr-draggable " style="" /> </p><p></p><p></p><p>The chart is both about recycle and about heat buildup.</p><p></p><p>The SB-700 should be vaguely similar. You will be able to see what works.</p></blockquote><p></p>
[QUOTE="WayneF, post: 237382, member: 12496"] It is just the internal flash that cannot... I think the SB-700 should do repetitive flashes, if not going too fast to allow recycle. For example, the SB-800 has a repeating mode with this rate/power chart in the manual. [IMG]http://www.scantips.com/g2/repeat.jpg[/IMG] The chart is both about recycle and about heat buildup. The SB-700 should be vaguely similar. You will be able to see what works. [/QUOTE]
Flashes
