I just picked up a very nice used AF-S 24mm f/1.8G. It looks almost unused. My testing showed it was softer, even at the center, than expected wide open but it did well after stopping down to 2.8 or 4. Lab tests in the reviews showed that it should have still had excellent center sharpness wide open so I did the autofocus fine tuning thing. Sure enough, it needed a +14. It's a sweetheart now... plenty sharp even at f/1.8.
I wonder if that's why someone sold this lens? It really did look barely used; hardly a mark on the mount. On the other hand, unless you did a careful test, you might never notice any autofocusing error in a wide angle like this. Anyway, I'm glad to know it's performing at its best now.
The testing is fun the first time but gets tedious on additional lenses, but I make myself do it each time I get a new one. I don't use a testing tool; I set up a still life or shoot a cluttered desktop with lots of small detail and with a good target to focus on in the center. I use a tripod and/or flash to eliminate camera movement. I view the focus area at three or four hundred percent and compare all the shots in pairs split-screen until I find the one that looks sharpest. Surprisingly, it's usually fairly easy to pick the winner.
One thing I haven't done is compare the tuning at different distances. Do you think a lens with the autofocus fine-tuned across the room (or closer) will still be at its best near infinity? Like I mentioned, I find the testing tedious, but maybe I'll be inspired to do a tuning at different distances test... or not...
