Bracketed shooting with remote release possible?
Gadzooky
Hi. I've been pouring over the controls of my D5100 and I can't find any way to set the camera to shoot in bracket release (i.e 3 photos at once) with the ML-L3 infa-red release. As far as I can see it's one of the other. I was wondering if the more experienced users know if it can be done, of if there is a cheat or work around? Thanks.
The ML-L3 allows for a single shutter depression, so you can't use it for continuous shooting (i.e. hold it down). You can press it 3 times in a row though and it will do your bracket series.
If you want to use a remote for continuous shooting then you'll need to use one that wires into the port on the camera's side. I have two, a Vello Shutter Boss, which is a nice wired remote that also works as a great intervalometer tool (far easier to understand and program than the in-camera method), and a Vello FreeWave RF remote, which sits on your hotshoe and wires in, but has an RF wireless remote that will trigger from up to 300 ft. away and does not require line of sight. The FreeWave has several modes: single press, continuous, bulb and timer.
If you don't have any potential need for the other functions then the press-press-press method with your current remote works fine (I used it for 18 months before I needed something else). Otherwise it's time for another remote.
Or (thinking as I type - a dangerous thing) set your camera in self-timer mode for 3 consecutive shots spaced at minimum time apart and the minimum delay (2 sec). This should automatically complete your bracket series, but it will mean you have to anticipate the 2 second delay before the first shot, so if you're waiting for a "moment" to happen, you could miss it.
Mike D90
If the camera is set to auto bracket 3 shots then the camera should bracket with one shutter release shouldn't it? Ah, never mind. It won't.
Not for exposure bracketing, unless you are in a continuous shutter mode - which is a separate spot on the same dial as the the setting for the IR remote, so you can't do both.
