Nikon DSLR Cameras
D3200
Battery grip
<blockquote data-quote="skene" data-source="post: 499052" data-attributes="member: 13155"><p>adds comfort... however for a D3XXX/5XXX series... you are stuck to aftermarket, and if you want to shoot in portrait mode.... There is a signal cable that you need to attach, so that the shutter release button will work on those series...</p><p>Other than that I feel it helps balance out smaller and larger cameras by adding a bit of gripping room to them. If you have large hands, you will understand what I mean.</p><p>I have and use a battery grip on all of my cameras.</p></blockquote><p></p>
[QUOTE="skene, post: 499052, member: 13155"] adds comfort... however for a D3XXX/5XXX series... you are stuck to aftermarket, and if you want to shoot in portrait mode.... There is a signal cable that you need to attach, so that the shutter release button will work on those series... Other than that I feel it helps balance out smaller and larger cameras by adding a bit of gripping room to them. If you have large hands, you will understand what I mean. I have and use a battery grip on all of my cameras. [/QUOTE]
Nikon DSLR Cameras
D3200
Battery grip
