Photography Q&A
Aperture setting help
<blockquote data-quote="hark" data-source="post: 625907" data-attributes="member: 13196"><p>Bottom line is in Aperture Priority, you select your aperture. You also set your ISO (if auto ISO is turned off). To make the image come out with the proper exposure, the camera will select the shutter speed. Either use a smaller aperture (higher f-stop number) or lower your ISO if possible to make the camera choose a slower shutter speed.</p></blockquote><p></p>
[QUOTE="hark, post: 625907, member: 13196"] Bottom line is in Aperture Priority, you select your aperture. You also set your ISO (if auto ISO is turned off). To make the image come out with the proper exposure, the camera will select the shutter speed. Either use a smaller aperture (higher f-stop number) or lower your ISO if possible to make the camera choose a slower shutter speed. [/QUOTE]
Photography Q&A
