Nikon DSLR Cameras
Out of Production DSLRs
D90
55-200mm Lens problems with D90
<blockquote data-quote="Horoscope Fish" data-source="post: 211912" data-attributes="member: 13090"><p>With the lens mounted and set set to AF, if you point the camera at a close object and then a distant object, and back and forth between the two, can you hear/feel the lens motor attempting to get a focus-lock? </p><p></p><p>If you *can't* hear/feel the lens attempting to get a focus-lock then I'd say the problem is probably with the internal focus-motor of the lens. </p><p></p><p>If you *can* hear/feel the lens attempting to get a focus lock but you can't get a clear picture even when it thinks it has, then I'd say it's a "communication" error between lens and camera body.</p><p></p><p>The question about being able to use Manual focus would be very telling, too...</p><p></p><p><span style="color: #FFFFFF">......</span></p></blockquote><p></p>
[QUOTE="Horoscope Fish, post: 211912, member: 13090"] With the lens mounted and set set to AF, if you point the camera at a close object and then a distant object, and back and forth between the two, can you hear/feel the lens motor attempting to get a focus-lock? If you *can't* hear/feel the lens attempting to get a focus-lock then I'd say the problem is probably with the internal focus-motor of the lens. If you *can* hear/feel the lens attempting to get a focus lock but you can't get a clear picture even when it thinks it has, then I'd say it's a "communication" error between lens and camera body. The question about being able to use Manual focus would be very telling, too... [COLOR="#FFFFFF"]......[/COLOR] [/QUOTE]
Nikon DSLR Cameras
D90
