Post your low light long exposures
J-see
I had no idea what I was doing and just put the cam on its back pointing upwards. That's about the only method I could think of in the middle of a town.
I was even surprised it had dots on it.
Next I might read something about what I am actually supposed to do.
J-see
If you point upwards with a hood on, it's pretty hard for stray light to hit the lens. ;)
The hardest part is to focus on infinity when you don't see where that infinity is. I intensely dislike there's no infinity 'stop'.
wornish
There is an infinity mark on most lenses, but I agree the focus ring normally rotates past the mark. I find its best to rotate all the way and then back off a little. You can hand-hold the camera and use live view to get the stars crisp at infinity, then put it on the floor to take the shot. The ~ 2 meter won't make any difference when focus is set on infinity ;)
J-see
I have the infinity solved. I just point at the church, it's far enough and there's constant light on it. I switched lenses again but I need to read up on this. I haven't even got a clue how to process this.
Last attempt for today. The dots are there but that's about it. I think I need to bring down ISO a lot more. I'm gonna push it back to 100 next time.
Scott Murray
Also try and set your white balance to cloudy or something, it may help.
J-see
If it isn't clouded tonight I'm going to take the D3300 and 10-24mm out into the fields.
I've shot a lot inside-out last night and noticed that even while on a pod or surface, the cam picks up vibrations and many shots look as if I used a microscope to shoot bacteria.
Hardest is going to find a light-low area. If you look at this map it becomes obvious star photography isn't the best in this country.
Blue Marble Navigator - Night Lights 2012
We're the Christmas tree of Europe.
J-see
I decided to start walking to a reasonable unpolluted area an hour before the right shooting time and when I arrived directly learned a new lesson. If you go shoot in total darkness, bringing a flashlight wouldn't hurt. It's pretty hard to see the front of the cam using the LCD as light source and a lighter didn't work well in the wind.
After an hour of practicing getting cold the only thing in the sky was clouds.
I tried to get some other night shots while walking back home.
Scott Murray
This is a very nice shot.
Deezey
[MENTION=31330]J-see[/MENTION] , my ball cap has built in led flashlights. Great little gizmo for hands free operation.
Lovely shots too by the way.
J-see
It's one of those things you don't think about until too late. I had packed two cams, some lenses to try, the tripod and dragged all that along on an hour long walk only to discover I couldn't set my lens at infinity because I didn't see anything. ;)
Luckily once in a while the moon was clear and I could quickly focus it on that.
centaur
Do you have some filter on this photo?
J-see
What do you mean with filter on the photo? Outside filters like PS ones? The shot is processed in LR but I didn't use any outside filter. Only the settings, brush and LR's graduated filter to selectively adjust parts. I hardly ever use filters besides the borders of perfect effects.
This is the shot as it rolled out of the cam.
I forgot to use exposure compensation and overexpose like crazy which is why I lost most tone info in the lower part of the shot. With some brushing and loads of desaturation I could hide most of that.
Gobae
Back when my uncle was in the hospital with cancer, I'd head out after "visitor's hours" had ended to unwind from the stresses. Here's some of the shots I got.
Gobae
Here are some others that I've taken over the years.
Building downtown Albany, NY
Forge fire with red hot iron.
Fireworks at the Schaghticoke Fair
Celtic Reenactor at Samhain
