need help
wheelgunner
HELLO!
I COULD USE SOME HELP!
HAVING A PROBLEM WITH MY D7100
WHEN I TAKE A PICTURE IT DOSNT APEAR ON BACK SCREEN! BLACK SCREEN
ALSO MY DELETE WONT WORK! FROZEN IMAGE!
ALL OTHER THINGS WORK MENUE ETC!
I WOULD APPRECIATE ANY HELP!
THANKS! WHEELGUNNER!
BF Hammer
The first problem is because Image Review is turned off. It is under the "Playback Menu" (might be just the play icon in the menu system). Also hiding in there is the setting for how the Delete button behaves. Factory default setting requires you to press delete a 2nd time to confirm you want to delete the image.
wheelgunner
wheelgunner
HELLO BF!
THANK YOU SO MUCH FOR THE REPLY!
IMAGE REVIEW IS TURNED ON!
TRIED THE FACTORY RESET BUT DIDNT WORK!
THANKS FOR YOUR HELP ANYWAY!
BEST REGARDS! WHEELGUNNER!
Peter7100
You could try this as it has helped a few people with different issues.
1. Switch off
2. remove battery and card
3. switch on
4. Hold down the shutter for at least 15 seconds
5. switch off
6. re-install battery and card
7. switch on and keep your fingers crossed.
