Needa
Challenge Team
Your best bet would be to take some images and test different things. IMO gray scale is usually best if you have a wide range, everything from black to white. The image of the two women appears to have had the blacks saturated or the black point moved. Sure others can provide better answers.
Dawg Pics
NIK Tools Silver Efex will get you there as well. It has presets and adjustments. If you increase the "structure," it highlights the textures and gives you that kind of look with hard edges.
Template Compilation Error
