I cant control the shutter speed !
samasama
Hi,
i only can see
M 3 F3.5
P low F3.5
S 3 low
A low F3.5
I have read a lot about shutter speed that you can control sequences of numbers.
gqtuazon
Gear Head
Hi,
i only can see
M 3 F3.5
P low F3.5
S 3 low
A low F3.5
It will help out if you fill out your profile and provide more details.
How long have you been using your camera? Have you read the owner's manual? Care to post a sample image?
grandpaw
You do not have enough light on any mode so I will ask the obvious question, is your lens cap on the lens? You ask us what your problem is and give no information about any of your equipment. As stated before, it would be helpful if you would fill out your profile or at least give us some information here on this post. Jeff
Disorderly
Put the camera in the M or S mode. Press the shutter button halfway down to engage the meter. Now turn the dial on the back to change shutter speed.
