D3100/D3200 Confused
Vyenkatesh
Hello,
I have used S550 for 3 years and now I feel the limitations of it. Till few months back I was using it only for occasions and now I am using it much more and feel of upgrading to either D3100 or D3200. I feel I should go for D3100 and get some additional lens instead of going for D3200. I will not be upgrading the camera so soon.
After going thorugh many threads I was a bit confused about my thoughts of whether to go for D3100kit+additional lens or D3200 kit and go for additional lens at later stage.
I am an amature shooter and will not use much additional features at this moment.
Can experts help me to overcome the dilemma to decide between these two options.
Thanks in advance.
Vyenky
Just-Clayton
I have two cameras. The 3100 and 300s. I still use the 3100 a lot. It's a great camera. I do a lot of hand held macro and my 300s gets a little heavy. As for upgrading to a 3200, I wouldn't.. Don't let the 3100-3200 comparison confuse you. The upgrades aren't needed. I would save up for the lenses.
Nikon Photographer
D3200 v D3100
Significantly better image quality 81.0 vs 67.0
More than 20% better image quality
More dynamic range 13.2 EV vs 11.3 EV
1.9 f-stops more dynamic range
Lower noise at high ISO 1,131 ISO vs 919 ISO
The D3200 has a slight edge (0.3 f-stops) in low noise, high ISO performance
Much higher resolution screen 921k dots vs 230k dots
More than 4x higher resolution screen
Much higher true resolution 24.1 MP vs 14.2 MP
Capture around 70% more detail in your photos
Better color depth 24.1 bits vs 22.5 bits
Distinguishes 1.6 more bits of color
Has an external mic jack Yes vs No
Record high quality audio with an external microphone
Better maximum light sensitivity 6,400 ISO vs 3,200 ISO
The D3200's maximum light sensitivity is 1 f-stop better
Shoots faster 4 fps vs 3 fps
More than 30% faster continuous shooting.
If it was me, I would have to go for the D3200 and get some better glass at a later stage
stmv
3200 just got a Gold Award, my vote, 3200, then you will have a camera that will not need upgrading for a while.
