which zoom lens is better?
msieee
plz suggest me a zoom lens. in my mind i had
nikkor 18-200mm VR II
nikkor 55-200mm VR
nikkor 55-300mm VR
nikkor 70-300mm VR
sigma 18-200mm
plz tell me which one will be better on my D5100
TedG954
While I'm sure it's not the best lens, I have been very satisfied with my 55-200 VR. For the cost, I believe it is a good value.
gqtuazon
Gear Head
I am assuming that you want a general walk-around lens. If you don't like to change lenses outdoor, then the 18-200mm might be what you are looking for. They are all great with good light especially when stopped down to f7.1 or f8.
WhiteLight
I had a very similar dilemma between the 55-200, 55-300 & 70-300.
Did a LOT of reading around and realized it mainly depends on your needs & of course your budget.
i finally decided to go in for the 70-300 & it is really quite awesome, i feel i made the right choice.
of course, the 18-200 is more expensive & has a lower f stop of 3.5 which obviously means better photos in lower light.
if you can afford that, then i guess that would be the best.
otherwise the next best choice is the 70-300 me thinks
msieee
thanks all for their reply.
my dilemma is that dose 70-300mm will work well with the DX body as that a FX Lens. !8-200mm has the sharpness issue at higher zoom. again as i have a 18-55mm as kit is it worth to get a 18-200mm. coz if i do with others like 55-200mm or 70-300mm then i can also get a 85mm Macro lens for me with the budget of 18-200mm, plz suggest me get a 18-200mm is worth as killing single gun for every day normal use.
slowpoke
I use my 70-300mm nearly all the time.To me it's a great all around lens.Mine also has a Macro switch.The price was right too.
WhiteLight
Correct. Since 70-300 is a FX lens, on a DX body you'll be using the best part of the optics.
Which means it will work very well.
The Nikon 18-200 is an awesome lens, you gain 2 f stops which will make it good even in low light conditions.
and you got it right, barring the costs (and your specific needs)the Nikon 18-200 would be choice 1 & 70-300 choice 2.
AC016
nikkor 55-200mm VR
nikkor 55-300mm VR
nikkor 70-300mm VR
sigma 18-200mm
Once again, don't overlap your lenses. You already have the 18-55; therefore, go for something like the 55-200. But no need for another lens that gives you the same 18-55 focal length as your kit lens. I have the 55-200 VR and it is the best lens you will ever get for the price.
slowpoke
is that Nikkor AS-F FX 70-300mm how is the macro performance of it
Sorry new here,Sigma DG 70-300mm 1:4-5.6 I'm sure the Nikkor is far superior to the Sigma,except the price. The Macro works fine.
Sigma has many good reviews on the lens on line.Hope this helps.
gqtuazon
Gear Head
It appears this is more of a money issue than a lens selection issue. Sell your 18-55mm and get the Nikon 18 - 105mm with VR. This will give you a little bit more extra reach and don't need to spend more for the 18-200mm.
