White-balance preview?
lostnomore
I'm just wondering if there's any sort of feature on the D750 where you can preview the effect of a WB setting before you actually take a shot? Or do you just select a ballpark WB setting, take a shot, play it back, then adjust if needed until you get the right setting?
You do have to activate live view preview in the menu system first. Don't remember where it is right off but I do know I had to find out why mine did not work and discovered it has to be turned on first.
lostnomore
I'm dredging up this thread again because although Live View is the only solution to seeing a 'real time' effect of WB adjustment, I'm not able to change sub-categories of WB, for example Fluorescent 3 to 4 or from Auto 1 to 2. Any ideas on how to do this, or do I have to always go to White Balance in the Photo Shooting Menu to do this? You also can't do this using the dedicated WB button on the back of the D750, unless somebody knows something that I'm missing.
