D7200 and Tamron 90mm Macro - issue?
dlwilliams48
I am having a bit of an issue with getting my Tamron 90mm Macro to focus accurately on my new D7200. It gives awesome results on my D7000 but on the D7200, not so much. I currently have the AF Fine-assist dialed in to -20 (the max) to correct the focus. I haven't taken it out to see the results yet, but I have been trying various combinations of adjustments and still not satisfied. Update: I just checked my D7000 and had it set on -16 for the Tamron, so hopefully the -20 on the D7200 will give satisfactory results. Wondering if anyone else is using the Tamron 90mm Macro and how it is working out.
ingo
Looks like I´ve meet the same problem but in the opposite direction.
The Tamron 90 mm Macro was not that good on my D7000 but almost perfect on my D7200 now.
(I needed to correct the fine tuning in the D7000 for this lens)
Example from today - ok pretty flat picture, but the focus is absolutely correct (evidence in a fire case)
http://www.petzny.de/tam.jpg
Is the focus correct on your D7200 with all your other lenses?
best regards,
Ingo
