FS: MeFOTO RoadTrip Aluminum Tripod - No Longer Available
RocketCowboy
Purchased this MeFoto from Amazon while on a week long trip to Las Vegas in March. Only used on that trip and hasn't replaced my carbon MeFoto for regular travel carry. Looking for a new home for this steady stand.
Shipping in the lower 48 states via FedEx or UPS. Pricing includes shipping.
List Date: 9/4/2015
For more info, click here to view the original listing: FS: MeFOTO RoadTrip Aluminum Tripod
This item is no longer available.
nikonites
Bill16
Re: FS: MeFOTO RoadTrip Aluminum Tripod
Hey my friend, what weight capacity is it rated for? I'm short so I'm not worried about the max night, but how low can it go without upending the center shaft? It sure looks like a cool little set up! :)
RocketCowboy
Max load is 17.6lbs. Max height without using the center section is 53". I did not have any issues with this tripod holding a gripped D7100 and either the 24-120mm/f4 or the 16-35mm/f4...both good size lenses.
Bill16
Cool but I need to know how low it can go too? I have great tripods, but no real small compact types of tripods! I'm using two Gitzo tripods, a carbon fiber and a aluminum both with ARCA SWISS ball heads! But a compact model might be handy to put in the car for unexpected times a tripod might be good to use! :)
But what is the lowest setup height buddy? :)
RocketCowboy
Website says minimum height is 15", but that seems high. You can reverse the center column and hang the camera below, so I'm pretty sure it gets lower than that.
Bill16
Thanks buddy! Sounds pretty good! I will think on it, and maybe if I can, I'll pm you! :)
