Noise when turning camera on/off?
senna41
Hey all!
I tried searching the forum and the manual for this, but I didn't have any luck. Apologies if this has been discussed already.
Does anyone else's D750 make a very quiet "chime" when the camera is turned on or off? I suppose you could also say it sounds like a faint, high-pitched beep. I made a sound recording of it. You'll more than likely need to turn your speakers up
It's not replicable 100% of the time.
Does anyone else's do this?
Carl7100
Hi,
I had a similar issue with my D7100 making a high-pitched sound when the camera was turned on and off. It turned out it was the automatic sensor cleaning that was set to run at power on and off. I just changed the setting in the menu so it was only done manually and the noise disappeared.
On a D7100 the command is located here:
Menu -> Setup Menu -> Clean image sensor -> Clean at statup/shutdown and set it to <Cleaningoff>
Hope this helps
Carl
Mahater
Hi,
Hope this helps
Carl
Thanks I also had this problem...and it was very annoying...it helped... appreciate it🥺😎
Bikerbrent
Welcome aboard, Mahater enjoy the ride. We look forward to seeing more posts and samples of your work.
Someone will be along shortly to help you out.
