First Pic chosen from new 910 Speedlight
The_Meridian
I'm brand new with a speedlight and thought this came out great for experimental shot.
What say you?
Artistic intent/summary of the photo: My intent was to test my new sb910
What specifically do you want feedback on? Did I use the speedlight effectively?
Read more: http://nikonites.com/photo-critique/22501-first-pic-chosen-new-910-speedlight.html#ixzz30hF7KCdS
[Image]
Make = NIKON CORPORATION
Model = NIKON D3100
Orientation = top/left
X Resolution = 240
Y Resolution = 240
Resolution Unit = inch
Software = Adobe Photoshop CS6 (Windows)
Date Time = 2014-05-03 18:57:54
Exif IFD Pointer = Offset: 220
[Camera]
Exposure Time = 1/60"
F Number = F5.6
Exposure Program = Not defined
ISO Speed Ratings = 3200
Exif Version = Version 2.21
Date Time Original = 2014-05-01 23:21:59
Date Time Digitized = 2014-05-01 23:21:59
Shutter Speed Value = 5.91 TV
Aperture Value = 4.97 AV
Exposure Bias Value = ±0EV
Max Aperture Value = F5.66
Metering Mode = Pattern
Light Source = unknown
Flash = Flash fired, compulsory flash mode, return light detected
Focal Length = 55mm
Subsec Time =
Subsec Time Original =
Subsec Time Digitized =
Color Space = Uncalibrated
Exif Image Width = 4608
Exif Image Height = 3072
Sensing Method = One-chip color area sensor
File Source = DSC
Scene Type = A directly photographed image
CFA Pattern = [G,B],\r\n[R,G]
Custom Rendered = Normal process
Exposure Mode = Auto exposure
White Balance = Auto white balance
Digital Zoom Ratio = 1x
Focal Length In 35mm Film = 82mm
Scene Capture Type = Portrait
Gain Control = High gain up
Contrast = Normal
Saturation = Normal
Sharpness = Normal
Subject Distance Range = unknown
A431 = 3760032
A432 = 180/10, 550/10, 35/10, 56/10
A434 = 18.0-55.0 mm f/3.5-5.6
[GPS]
[Interoperability]
[Thumbnail Info]
Compression = JPEG Compressed (Thumbnail)
X Resolution = 72
Y Resolution = 72
JPEG Interchange Format = Offset: 966
JPEG Interchange Format Length = Length: 3751
[Thumbnail]
Thumbnail = 160 x 107
DraganDL
Me says, you got yourself a good flash unit. However, you need to use a 910 in many different environments/situations to really feel it's "muscles" (this photo of a boy, somewhat noisy, could have been taken with the built-in flash unit just as well).
I just came back home from the funeral where I had taken about 150 shots with the built-in flash unit, quite successfully.
Scott Murray
What say you?
Just a heads up but you should read the guidelines.
PHOTO SUBMISSION RULES
1. Only one photo submission per day (24 hours). We don't want the forum to be monopolized by a single member.
2.
Upload one image in your post. If you have a set of images, just provide a text link, either to your member gallery here on Nikonites.com or off-site. If you are unsure how to do this, please ask.
3.
Include as much info as possible along with your image:
  • EXIF data
  • Artistic intent/summary of the photo
  • What specifically do you want feedback on?
Photo submissions will be moderated. If the above 3 items are not included along with your photo, your thread will be deleted.
The_Meridian
Oh, sorry, missed that. Please feel free to delete this or any other post as you see fit. I will endeavor to be more careful in the future.
Scott Murray
All you need to do is include your EXIF details and maybe a bit more about what you wanted.
Sent from my C6903 using Tapatalk
