kanhatiger
Not had my camera out for a while, so with some sunshine around decided to get out into the woods for some shot's, Set my camera up on the tripod with the mb10 battery and a wireless remote, using my 200-400 lens, giving you as much info as possible about my set up, went to push the shutter and it did not function, i got a code r06 in the shutter counter, read through a bit on google saying clean the connection's between the lens and the camera, if that does not work, do a reset, which i did after cleaning did not seem to work, the camera went intermitant on the shutter and is now ok, i notice when i put the shutter down half way i get an r13 showing, but can take the shutter down now and get it to fire well, has anyone else had this type of experience and if so how did you cure it, or is it a setting i am not aware of ?
