How to change TTL flash mode
vikramsamal
I wanted to use the flash in reversed lens and it says that change the TTL flash mode to do that. How do I change the flash from TTL mode to other mode? Thanks in advance.
Mike D90
Once you reverse the lens TTL will likely not work anymore. You need to change this in the camera settings menu under "Flash/Bracketing". Select Flash control and then change it to Manual.
I assume you are trying to do reverse lens macro. If so, built in flash without some kind of modifier is gonna suck.
You really need either a ring macro flash or an off camera flash unit with built in slave or using a radio popper trigger or flash sync cord.
