Macro Ring Flash Question.
Scott Murray
What are you going to be using them for? Insect macros? Or mainly flowers etc? The reason I am asking this is because you need a good diffuser with these flashes as to not blow out portions of the insect/bug. With most macro set ups you can get away with a speedlight and a homemade diffuser / Snoot that directs the light slightly in front and above the object you are photographing. Click the above link to see images of such.
HotGates
I will be using for both, when I was with Canon I had the canon ring flash that worked pretty good for macro, I do have a SB-910 AND SB-800.
Scott Murray
Well honestly I would look at some homemade diffusers etc before outlaying $$$$'s for a ring flash. I was going to do the same but have found that even my onboard flash with the right diffuser works a treat.
