Usability of Lexar 4GB SDHC Memory Card on D70
balan
I recently acquired an old Nikon D70. Also I ​have a Lexar Multi-Use SDHC 4GB Memory Card. The D70 User Manual recommends: "Lexar Media 40× WA USB 4GB". The label on my card reads "Lexar Multi-Use SDHC 4GB". The nomenclature in the recommendation and the labelling are confusing. Can I use it on my D70? Thank you.
mikew_RIP
Don't know if ime reading this right but you have a SD card and the D70 uses compact flash,if so you would need an adapter,if that's what your asking then sorry :D
balan
Thanks very much Don for your reply. Since the pin type and arrangements are quite different in the two, does it call for the use of an adapter? If so. how do I specify it while purchasing?
​_ balan
The SD card you have is not that expensive or really fast enough to begin with. I would suggest you just buy the correct CompactFlash© (CF) card and use it. I think you will be a lot better off to start with.
