Setup my speedlight on a stand to take a few shots tonight. D40 is on manual, 1/200, F4, WB: Flash.
Flash was on 1/4 and 1/8 power. Took about 10 shots, all of the sudden, Camera won't fire.
Message: 'Lighting is poor. Flash recommended'
I am using the cheaplights trigger/receivers. Swapped to a freshly charged battery. Flash fires fine using test button and pretting the button on the trigger.
Swapped my 50mm for the 18-55mm, same message. No luck in the manual or a google search. Any ideas?
Thanks.
Thanks.
