This may be of help...
Camera Settings:
Every venue is different. Shoot in manual mode only – i usually use manual focus, but that’s not necessary, AF is ok. Open up the aperture as wide as it can go (ideally f1.8 or 1.4 – but you can work with other lenses with more light..flash or ambient)
My usual settings:
- 1/150 shutter
- f1.8 aperture
- ISO 800 or 1600 or 400
Enough to freeze motion, but not override and flatten the ambient light.
If you’re shooting in a venue with absolutely no available light…or in ‘available darkness,’ and you need to use a flash. I normally shoot with direct flash from high above the left side of the camera. (Flash in my left hand) Settings are as follows:
- F8
- 1/250 or 1/500 shutter
- ISO 200 or 400.
- Flash at 1/8th power.
If there’s some cool ambient light going on, try something more like 1/150 shutter, f4, and a really low flash setting (1/64 or less)
