Is anyone using the Nikon 35-70 f/2.8?
TedG954
I've been doing a lot of research on this lens and I have been quite impressed with its reviews. Some have rated the output quality as good as the 24-70, and some have rated it higher. I'm looking at one for $250. Compared to $1.9k for the 24-70, that's quite a buy. I was just looking for other user's impressions.
Thanks.
I have this lens and here's my humble opinion.
When I first got mine, the front element looked a little muddy and I had read that it was easily removed and cleaned. This helped the 2.8 function quite a bit.
It's a very sharp lens starting at F4. At 2.8, it lacks contrast a bit but shots can be improved quite a bit in Post. But, against light, it flares and become soft, almost ethereal. But it's very well made and has a macro function that can only be used at 35mm and manual focus. So for the price, I think it's a bargain.
I'll try to find shots done with it (I got it when I first got the D700) and post them here.
Here's a shot taken at 35mm f:5.6, 1/60s, iso 800 hand held.
I think this is a very sweet lens and it was one of Nikon's top seller when film was King.
Here are a few shots from my Gallery. Hope it helps you. I think I paid around 350 for mine I thought it was way cheaper than the 24-70. But I eventually had to have the 24-70. So, maybe just save for it. It's one of Nikon's best lens, but expensive they are...
stmv
well,, that is why I have a 20-35 and a 35-70 2.8s,, as my quality wide angle and mid zooms.
The 35-70 takes incredible pictures, sharp, little distortion, built tough, and compact.
it is a push pull, but then all my early zooms where push pulls, so I am conditioned
Some might have dust in them, and have to be cleaned up...
So, from a dollar to dollar comparison its very hard to beat. any decent one under 350 dollars is a bargain.
TedG954
Excellent photos Marcel and I'd buy the lens based on those examples, but.......... the AF didn't work. I don't know what the exact problem was, but it didn't work when I mounted it on my camera. Oh, well. The hunt continues. Thanks for the assist.
jwstl
I have the 35-70 2.8 and used it regularly back in the day but not much lately. I don't shoot at 2.8 as much so I've been using my 24-85 AF-S more. It's lighter, has more range, focuses faster, and it's plenty sharp. Having said that, the 35-70 really is excellent as long as the weight (heavier than most zooms in the range but not the 24-70) and focus speed aren't issues for you. KEH sells EX ones for around $500 so if you can find one in similar condition for less grab it.
TedG954
Thanks. Like you, I've decided to stick with my 24-85.
ernest
[SUB]I own the Nikon 35-70mm f2.8 AF for quite sometime now and it takes time to really love it. [/SUB][SUB]I am using the 35-70mm only for video with canon SLR because it is a bargain if compared to the expensive Canon 24-70 L.[/SUB][SUB]Honestly I rarely use it for photography, because in most cases every time I mount it on the camera I ended up switching to wider or portrait lens.[/SUB]
[SUB]The 35-70 f2.8 is sharp from 35 to approximately 60mm at f2.8 but at 70mm it often produces soft result especially when it is pointed to bright areas. It has bluish chromatic aberration especially in high contrast. The best result if I stopped it down to f4 and the picture looks perfect. The color of 35-70mm is similar to my 20-35mm f2.8 AF-D and 80-200mm f2.8. Optical quality is quite good, for lens under $300 (used). [/SUB]
[SUB]The AF is pretty fast but not as fast as my 20-35 or 50mm. Compared to 50mm f1.4 AF-D at f2.8, prime lens is always the winner, prime lens produces brighter image (almost 1 stop) with same settings, but the 35-70mm produces warmer color and at 70mm the “bokeh” can be quite “creamy”, if I take it at its closest focus distance which is 0.6 m. So I figure this lens performs well as candid and portrait lens.[/SUB]
[SUB]The worst thing about the Nikon 35-70 mm is the ergonomics. The push-pull zoom is quite hard to get it precise and the grinding autofocus noise is very annoying. I’ve tried the newer professional 28-70mm f2.8 AF-S lens, in my experience both the 35-70 and the 28-70 produces quite similar result but the zoom ring is smooth and precise, AF is silent and fast has shorter minimum focus distance and the 28-70 has 9 bladed diaphragm which the 35-70 only has 7. But the 28-70mm is gigantic and heavy, the lens barrel is huge and I find myself hugging it all the time to get unshaken picture under low light situation. I use Nikon D700 and 35mm is still pretty wide, so with the 35-70, I could step back a little about half a meter and I can cover wider focal length similar to 28mm. So I’ll pass the 28-70mm f2.8 because of its huge size.[/SUB]
[SUB]I’ve once borrowed Nikon 24-70mm f2.8 AF-S G and done some testings, and it is heaven! If someone used to work with the Nikon 35-70mm f2.8 and switch to 24-70 mm f2.8 AF-S G, it is like switching from an old jeep to a modern big SUV, everything feels smooth and easy, it is very seriously designed by Nikon and when you grab the lens barrel, it feels right, the AF is fast and dead on and the sharpness is superb.
I’ve tried Tamron 28-75mm f2.8 for Nikon, because it is more modern lens it has better coatings, which is designed during digital era, which means it handles chromatic aberration much better than the old Nikon 35-70mm f2.8. Like I said earlier, [/SUB]
[SUB]it takes time to really love [/SUB][SUB]the old Nikon 35-70mm f2.8. It has great optics especially if stopped down to f4, it has fast autofocus (pro level lens grade) which is faster than the Tamron, it is well built and very tough lens but it only offers short mid-range 35, 50, 70 and that’s it.
If I you need a cheap high performance mid-range zoom lens I will recommend the cheaper Nikon 28-105mm f3.5-4.5, it produces slightly less contrast image compared to the 35-70 f2.8 but has macro ability ratio 1:2 at 105mm and it is lighter, goes from 28 to 105mm which will be great for travel lens or general purpose lens. The next choice is the Nikon 24-85mm f3.5-5.6 AF-S, and the best choice is the newer 24-85mm VR or skip the short mid-range and use the cheap but superior in low light 50mm f1.8D and try to move back and forth a little.[/SUB]
