If you are looking for awesome bokeh I cannot recommend the G-series f1.8 lenses enough. I have the 28, 50 and 85mm and they are all brilliantly sharp. For the modest difference in price ($40 on Amazon) I believe you're getting a better lens for your D600.
Here's a side-by-side I found comparing the two 85mm's, G lens on the left, D on the right.
Have you given any thought to the 105 f/2 DC or the 135mm f/2 DC.
thanks. I definitely see the smoother, less distracting bokeh, on the G version. Is it the same for the 50mm also? Alas, for now I ended up going with the 50mm and 85mm 1.8...both of which I thought were the D version, but turns out they're not. Essentially the same lens, but apparently not as good metering when used with flash..
I have definitely thought about the 135 2.0 DC as the Canon 135 f2L was my dream lens before (only $720 used or so). However, it's way out of my price range at the moment. There's an older MF 135mm f2.8 on CL right now for $80...
I've posted my first pics with the D600 + 85mm 1.8 (non-D). I am super pleased and immediately see a huge difference in quality of colors/dynamic range--not to mention sharpness and less noise... everything that I wanted...!
my first shots with a full frame!!! - a set on Flickr
