Run Time: 0.000660
Run Time: 0.000200
WHERE (`xf_thread`.`thread_id` = '32622')
Run Time: 0.000788
WHERE (`xf_post`.`thread_id` = 32622) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004961
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 13 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (490637, 492220, 492232, 508083, 508138))
Run Time: 0.002431
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 9 | Using index condition; Using filesort |
Params: 32622
Run Time: 0.000087
Params: 0,
Run Time: 0.000191
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=32622, 1715846727, , 0,
Run Time: 0.000130
WHERE (`xf_session_activity`.`user_id` = 21666) AND (`xf_session_activity`.`unique_key` = '21666')
Run Time: 0.000187
WHERE (`xf_thread_reply_ban`.`thread_id` = 32622) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000213
Run Time: 0.000207
bytes_sent | 12368 |
bytes_received | 313954 |
packets_sent | 124 |
packets_received | 1086 |
protocol_overhead_in | 4344 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 241153 |
packets_sent_command | 61 |
packets_received_change_user | 106 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 88 |
rows_buffered_from_client_ps | 88 |
rows_skipped_ps | 88 |
proto_binary_fetched_bit | 710 |
proto_binary_fetched_short | 260 |
proto_binary_fetched_int24 | 98 |
proto_binary_fetched_bigint | 758 |
proto_binary_fetched_decimal | 33 |
proto_binary_fetched_json | 572 |
proto_binary_fetched_blob | 252 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 239305 |
