Run Time: 0.000656
Run Time: 0.000232
WHERE (`xf_thread`.`thread_id` = '38346')
Run Time: 0.000640
WHERE (`xf_post`.`thread_id` = 38346) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002764
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 16 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (597191, 597227, 597229, 597259, 597556, 597738))
Run Time: 0.002120
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 8 | Using index condition; Using filesort |
Params: 38346
Run Time: 0.000080
Params: 0,
Run Time: 0.000124
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=38346, 1714892683, , 0,
Run Time: 0.000129
WHERE (`xf_session_activity`.`user_id` = 37799) AND (`xf_session_activity`.`unique_key` = '37799')
Run Time: 0.000191
WHERE (`xf_thread_reply_ban`.`thread_id` = 38346) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000156
Run Time: 0.000207
bytes_sent | 12384 |
bytes_received | 332181 |
packets_sent | 124 |
packets_received | 1088 |
protocol_overhead_in | 4352 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 259380 |
packets_sent_command | 61 |
packets_received_change_user | 108 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 90 |
rows_buffered_from_client_ps | 90 |
rows_skipped_ps | 90 |
proto_binary_fetched_bit | 669 |
proto_binary_fetched_short | 316 |
proto_binary_fetched_int24 | 119 |
proto_binary_fetched_bigint | 885 |
proto_binary_fetched_decimal | 32 |
proto_binary_fetched_json | 627 |
proto_binary_fetched_blob | 298 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 257365 |
