Run Time: 0.000403
Run Time: 0.000201
WHERE (`xf_thread`.`thread_id` = '20911')
Run Time: 0.000693
WHERE (`xf_post`.`thread_id` = 20911) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002693
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 6 | Using where; Using filesort |
Params: 20911
Run Time: 0.000089
Params: 0, 0
Run Time: 0.000162
Params: 0, XF\Pub\Controller\Thread, Index, valid, thread_id=20911, 1714645201, , 0, 0
Run Time: 0.000160
WHERE (`xf_session_activity`.`user_id` = 14162) AND (`xf_session_activity`.`unique_key` = '14162')
Run Time: 0.000196
WHERE (`xf_thread_reply_ban`.`thread_id` = 20911) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000233
Run Time: 0.000181
bytes_sent | 9840 |
bytes_received | 256267 |
packets_sent | 112 |
packets_received | 871 |
protocol_overhead_in | 3484 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 201488 |
packets_sent_command | 55 |
packets_received_change_user | 83 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 67 |
rows_buffered_from_client_ps | 67 |
rows_skipped_ps | 67 |
proto_binary_fetched_bit | 90 |
proto_binary_fetched_short | 122 |
proto_binary_fetched_int24 | 49 |
proto_binary_fetched_bigint | 325 |
proto_binary_fetched_json | 343 |
proto_binary_fetched_blob | 142 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 200334 |
