Run Time: 0.000393
Run Time: 0.000170
WHERE (`xf_thread`.`thread_id` = '25877')
Run Time: 0.000862
WHERE (`xf_post`.`thread_id` = 25877) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004584
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 20 | Using where; Using filesort |
Params: 25877
Run Time: 0.000104
Params: 0,
Run Time: 0.000180
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=25877, 1715210621, , 0,
Run Time: 0.000119
WHERE (`xf_session_activity`.`user_id` = 32425) AND (`xf_session_activity`.`unique_key` = '32425')
Run Time: 0.000172
WHERE (`xf_thread_reply_ban`.`thread_id` = 25877) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000245
Run Time: 0.000173
bytes_sent | 9847 |
bytes_received | 334514 |
packets_sent | 112 |
packets_received | 885 |
protocol_overhead_in | 3540 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 279776 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 81 |
proto_binary_fetched_bit | 260 |
proto_binary_fetched_short | 359 |
proto_binary_fetched_json | 623 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 277784 |
