Run Time: 0.000508
Run Time: 0.000179
WHERE (`xf_thread`.`thread_id` = '42666')
Run Time: 0.000647
WHERE (`xf_post`.`thread_id` = 42666) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002600
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 17 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (689421, 689424, 689560, 689782, 689783, 689784, 690208, 690209, 690210, 690211, 717425))
Run Time: 0.001194
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 11 | Using index condition; Using filesort |
Params: 42666
Run Time: 0.000087
Params: 0,
Run Time: 0.000141
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=42666, 1714236472, , 0,
Run Time: 0.000129
WHERE (`xf_session_activity`.`user_id` = 17696) AND (`xf_session_activity`.`unique_key` = '17696')
Run Time: 0.000167
WHERE (`xf_thread_reply_ban`.`thread_id` = 42666) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000185
Run Time: 0.000191
bytes_sent | 12464 |
bytes_received | 337213 |
packets_sent | 124 |
packets_received | 1092 |
protocol_overhead_in | 4368 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 264412 |
packets_sent_command | 61 |
packets_received_change_user | 112 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 94 |
rows_buffered_from_client_ps | 94 |
rows_skipped_ps | 94 |
proto_binary_fetched_bit | 870 |
proto_binary_fetched_short | 334 |
proto_binary_fetched_int24 | 126 |
proto_binary_fetched_bigint | 962 |
proto_binary_fetched_decimal | 35 |
proto_binary_fetched_json | 662 |
proto_binary_fetched_blob | 318 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 262280 |
