Run Time: 0.000440
Run Time: 0.000209
WHERE (`xf_thread`.`thread_id` = '27921')
Run Time: 0.000793
WHERE (`xf_post`.`thread_id` = 27921) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003378
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (397828, 398213, 398548, 399154, 399464))
Run Time: 0.001692
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 10 | Using index condition; Using filesort |
Params: 27921
Run Time: 0.000107
Params: 0,
Run Time: 0.000153
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=27921, 1714291803, , 0,
Run Time: 0.000152
WHERE (`xf_session_activity`.`user_id` = 17696) AND (`xf_session_activity`.`unique_key` = '17696')
Run Time: 0.000182
WHERE (`xf_thread_reply_ban`.`thread_id` = 27921) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000249
Run Time: 0.000210
bytes_sent | 12368 |
bytes_received | 353487 |
packets_sent | 124 |
packets_received | 1094 |
protocol_overhead_in | 4376 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 280686 |
packets_sent_command | 61 |
packets_received_change_user | 114 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 96 |
rows_buffered_from_client_ps | 96 |
rows_skipped_ps | 96 |
proto_binary_fetched_bit | 851 |
proto_binary_fetched_short | 382 |
proto_binary_fetched_bigint | 1080 |
proto_binary_fetched_decimal | 34 |
proto_binary_fetched_json | 716 |
proto_binary_fetched_blob | 360 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 278392 |
