Run Time: 0.000702
Run Time: 0.000207
WHERE (`xf_thread`.`thread_id` = '20099')
Run Time: 0.000937
WHERE (`xf_post`.`thread_id` = 20099) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003615
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 17 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (257306, 257322, 257697))
Run Time: 0.001821
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 3 | Using index condition; Using filesort |
Params: 20099
Run Time: 0.000115
Params: 0,
Run Time: 0.000191
WHERE (`xf_session_activity`.`user_id` = 11670) AND (`xf_session_activity`.`unique_key` = '11670')
Run Time: 0.000193
WHERE (`xf_thread_reply_ban`.`thread_id` = 20099) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000275
Run Time: 0.000205
bytes_sent | 11934 |
bytes_received | 339116 |
packets_sent | 118 |
packets_received | 1072 |
protocol_overhead_in | 4288 |
protocol_overhead_out | 472 |
bytes_received_rset_header_packet | 369 |
bytes_received_rset_row_packet | 123 |
bytes_received_prepare_response_packet | 71491 |
bytes_received_change_user_packet | 266635 |
packets_sent_command | 58 |
packets_received_rset_header | 41 |
packets_received_rset_row | 21 |
packets_received_prepare_response | 885 |
packets_received_change_user | 104 |
result_set_queries | 18 |
non_result_set_queries | 3 |
ps_buffered_sets | 18 |
ps_prepared_once_executed | 18 |
rows_fetched_from_server_ps | 86 |
rows_buffered_from_client_ps | 86 |
rows_skipped_ps | 86 |
proto_binary_fetched_bit | 400 |
proto_binary_fetched_short | 315 |
proto_binary_fetched_int24 | 126 |
proto_binary_fetched_bigint | 851 |
proto_binary_fetched_decimal | 27 |
proto_binary_fetched_blob | 310 |
com_stmt_prepare | 19 |
com_stmt_execute | 19 |
com_stmt_close | 18 |
bytes_received_real_data_ps | 264653 |
