Run Time: 0.000745
Run Time: 0.000259
WHERE (`xf_thread`.`thread_id` = '42581')
Run Time: 0.000807
WHERE (`xf_post`.`thread_id` = 42581) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002379
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 9 | Using where; Using filesort |
Params: 42581
Run Time: 0.000125
SELECT `xf_poll`.*
FROM `xf_poll`
WHERE (`xf_poll`.`content_type` = 'thread') AND (`xf_poll`.`content_id` = 42581)
Run Time: 0.000435
SIMPLE | xf_poll | const | content_type_content_id | content_type_content_id | 31 | const,const | 1 | |
- XF\Mvc\Entity\Finder->fetchOne() in src/XF/Mvc/Entity/Manager.php at line 366
- XF\Mvc\Entity\Entity->__get() in src/XF/ThreadType/Poll.php at line 24
- XF\ThreadType\Poll->adjustThreadViewParams() in src/XF/Pub/Controller/Thread.php at line 195
Params: 0,
Run Time: 0.000145
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=42581, 1715798597, , 0,
Run Time: 0.000102
WHERE (`xf_session_activity`.`user_id` = 27017) AND (`xf_session_activity`.`unique_key` = '27017')
Run Time: 0.000176
- XF\Template\Templater->renderTemplate() in src/XF/Template/Templater.php at line 1642
WHERE (`xf_thread_reply_ban`.`thread_id` = 42581) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000208
Run Time: 0.000240
bytes_sent | 10261 |
bytes_received | 279330 |
packets_sent | 124 |
packets_received | 927 |
protocol_overhead_in | 3708 |
protocol_overhead_out | 496 |
bytes_received_prepare_response_packet | 56054 |
bytes_received_change_user_packet | 222250 |
packets_sent_command | 61 |
packets_received_prepare_response | 752 |
packets_received_change_user | 89 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 71 |
rows_buffered_from_client_ps | 71 |
rows_skipped_ps | 71 |
proto_binary_fetched_bit | 108 |
proto_binary_fetched_short | 178 |
proto_binary_fetched_int24 | 70 |
proto_binary_fetched_bigint | 463 |
proto_binary_fetched_decimal | 20 |
proto_binary_fetched_json | 428 |
proto_binary_fetched_blob | 188 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 220863 |
