Run Time: 0.000625
Run Time: 0.000219
WHERE (`xf_thread`.`thread_id` = '32787')
Run Time: 0.000832
WHERE (`xf_post`.`thread_id` = 32787) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003440
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 11 | Using where; Using filesort |
Params: 32787
Run Time: 0.000088
Params: 0, O;
Run Time: 0.000146
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: O;, XF\Pub\Controller\Thread, Index, valid, thread_id=32787, 1715356415, , 0, O;
Run Time: 0.000095
WHERE (`xf_session_activity`.`user_id` = 40341) AND (`xf_session_activity`.`unique_key` = '40341')
Run Time: 0.000197
WHERE (`xf_thread_reply_ban`.`thread_id` = 32787) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000206
Run Time: 0.000196
bytes_sent | 9853 |
bytes_received | 285923 |
packets_sent | 112 |
packets_received | 875 |
protocol_overhead_in | 3500 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 231185 |
packets_sent_command | 55 |
packets_received_change_user | 87 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 71 |
rows_buffered_from_client_ps | 71 |
rows_skipped_ps | 71 |
proto_binary_fetched_bit | 143 |
proto_binary_fetched_short | 206 |
proto_binary_fetched_int24 | 84 |
proto_binary_fetched_bigint | 545 |
proto_binary_fetched_json | 450 |
proto_binary_fetched_blob | 217 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 229731 |
