Run Time: 0.000476
Run Time: 0.000167
WHERE (`xf_thread`.`thread_id` = '32207')
Run Time: 0.000897
WHERE (`xf_post`.`thread_id` = 32207) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003491
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (483527, 483558, 483586))
Run Time: 0.001372
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 7 | Using index condition; Using filesort |
Params: 32207
Run Time: 0.000092
Params: 0,
Run Time: 0.000150
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=32207, 1716299512, , 0,
Run Time: 0.000100
WHERE (`xf_session_activity`.`user_id` = 40001) AND (`xf_session_activity`.`unique_key` = '40001')
Run Time: 0.000179
WHERE (`xf_thread_reply_ban`.`thread_id` = 32207) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000236
Run Time: 0.000227
bytes_sent | 12343 |
bytes_received | 358303 |
packets_sent | 124 |
packets_received | 1091 |
protocol_overhead_in | 4364 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 285543 |
packets_sent_command | 61 |
packets_received_change_user | 111 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 93 |
rows_buffered_from_client_ps | 93 |
rows_skipped_ps | 93 |
proto_binary_fetched_bit | 678 |
proto_binary_fetched_short | 373 |
proto_binary_fetched_bigint | 1038 |
proto_binary_fetched_decimal | 31 |
proto_binary_fetched_json | 701 |
proto_binary_fetched_blob | 356 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 283312 |
