Run Time: 0.000457
Run Time: 0.000222
WHERE (`xf_thread`.`thread_id` = '38454')
Run Time: 0.000707
WHERE (`xf_post`.`thread_id` = 38454) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.005375
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (599096, 602589, 602675, 603461, 606010, 607055, 621833, 621870, 622008, 623893, 626584, 637619, 637715, 637864, 639998, 640385, 640542, 640763, 640844))
Run Time: 0.006812
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 31 | Using index condition; Using filesort |
Params: 38454
Run Time: 0.000169
Params: 0,
Run Time: 0.000169
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=38454, 1715937295, , 0,
Run Time: 0.000142
WHERE (`xf_session_activity`.`user_id` = 15675) AND (`xf_session_activity`.`unique_key` = '15675')
Run Time: 0.000250
WHERE (`xf_thread_reply_ban`.`thread_id` = 38454) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000210
Run Time: 0.000235
bytes_sent | 12592 |
bytes_received | 355967 |
packets_sent | 124 |
packets_received | 1115 |
protocol_overhead_in | 4460 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 283166 |
packets_sent_command | 61 |
packets_received_change_user | 135 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 117 |
rows_buffered_from_client_ps | 117 |
rows_skipped_ps | 117 |
proto_binary_fetched_bit | 2101 |
proto_binary_fetched_short | 422 |
proto_binary_fetched_bigint | 1374 |
proto_binary_fetched_decimal | 55 |
proto_binary_fetched_json | 821 |
proto_binary_fetched_blob | 372 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 280433 |
