Run Time: 0.000708
Run Time: 0.000241
WHERE (`xf_thread`.`thread_id` = '34707')
Run Time: 0.000934
WHERE (`xf_post`.`thread_id` = 34707) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.005652
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (521273, 523221, 523223, 523225, 524676, 524818, 525898, 527202, 527223, 528160, 532171, 534449, 537690, 539291, 541357, 541976, 544433, 546807, 547466, 547688))
Run Time: 0.009631
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 29 | Using index condition; Using filesort |
Params: 34707
Run Time: 0.000109
Params: 0,
Run Time: 0.000201
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=34707, 1716386497, , 0,
Run Time: 0.000177
WHERE (`xf_session_activity`.`user_id` = 15675) AND (`xf_session_activity`.`unique_key` = '15675')
Run Time: 0.000158
WHERE (`xf_thread_reply_ban`.`thread_id` = 34707) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000206
Run Time: 0.000182
bytes_sent | 12608 |
bytes_received | 354563 |
packets_sent | 124 |
packets_received | 1113 |
protocol_overhead_in | 4452 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 281762 |
packets_sent_command | 61 |
packets_received_change_user | 133 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 115 |
rows_buffered_from_client_ps | 115 |
rows_skipped_ps | 115 |
proto_binary_fetched_bit | 1982 |
proto_binary_fetched_short | 417 |
proto_binary_fetched_bigint | 1346 |
proto_binary_fetched_decimal | 53 |
proto_binary_fetched_json | 811 |
proto_binary_fetched_blob | 372 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 279075 |
