Run Time: 0.000714
Run Time: 0.000212
WHERE (`xf_thread`.`thread_id` = '27930')
Run Time: 0.000798
WHERE (`xf_post`.`thread_id` = 27930) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004833
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 20 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (399074))
Run Time: 0.001104
SIMPLE | xf_attachment | ref | content_type_id_date,content_type | content_type_id_date | 31 | const,const | 2 | Using index condition; Using where |
Params: 27930
Run Time: 0.000091
Params: 0,
Run Time: 0.000124
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=27930, 1715973229, , 0,
Run Time: 0.000093
WHERE (`xf_session_activity`.`user_id` = 36076) AND (`xf_session_activity`.`unique_key` = '36076')
Run Time: 0.000163
WHERE (`xf_thread_reply_ban`.`thread_id` = 27930) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000198
Run Time: 0.000220
bytes_sent | 12317 |
bytes_received | 353814 |
packets_sent | 124 |
packets_received | 1085 |
protocol_overhead_in | 4340 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 281054 |
packets_sent_command | 61 |
packets_received_change_user | 105 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 87 |
rows_buffered_from_client_ps | 87 |
rows_skipped_ps | 87 |
proto_binary_fetched_bit | 379 |
proto_binary_fetched_short | 363 |
proto_binary_fetched_bigint | 967 |
proto_binary_fetched_decimal | 26 |
proto_binary_fetched_json | 678 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 278941 |
