Run Time: 0.000691
Run Time: 0.000238
WHERE (`xf_thread`.`thread_id` = '15234')
Run Time: 0.000815
WHERE (`xf_post`.`thread_id` = 15234) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002901
Params: 15234
Run Time: 0.000069
Params: 0,
Run Time: 0.000178
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=15234, 1715976184, , 0,
Run Time: 0.000156
WHERE (`xf_session_activity`.`user_id` = 12299) AND (`xf_session_activity`.`unique_key` = '12299')
Run Time: 0.000200
WHERE (`xf_thread_reply_ban`.`thread_id` = 15234) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000230
Run Time: 0.000222
bytes_sent | 9840 |
bytes_received | 344831 |
packets_sent | 112 |
packets_received | 885 |
protocol_overhead_in | 3540 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 290052 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 81 |
proto_binary_fetched_bit | 250 |
proto_binary_fetched_short | 360 |
proto_binary_fetched_bigint | 943 |
proto_binary_fetched_json | 629 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 288042 |
