Run Time: 0.000666
Run Time: 0.000190
WHERE (`xf_thread`.`thread_id` = '28692')
Run Time: 0.000749
WHERE (`xf_post`.`thread_id` = 28692) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002921
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 14 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (414463, 414481, 415032, 415424, 448759, 453554))
Run Time: 0.003845
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 6 | Using index condition; Using filesort |
Params: 28692
Run Time: 0.000104
Params: 0,
Run Time: 0.000182
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=28692, 1716313156, , 0,
Run Time: 0.000135
WHERE (`xf_session_activity`.`user_id` = 27458) AND (`xf_session_activity`.`unique_key` = '27458')
Run Time: 0.000177
WHERE (`xf_thread_reply_ban`.`thread_id` = 28692) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000210
Run Time: 0.000197
bytes_sent | 12397 |
bytes_received | 323169 |
packets_sent | 124 |
packets_received | 1083 |
protocol_overhead_in | 4332 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 250409 |
packets_sent_command | 61 |
packets_received_change_user | 103 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 85 |
rows_buffered_from_client_ps | 85 |
rows_skipped_ps | 85 |
proto_binary_fetched_bit | 532 |
proto_binary_fetched_short | 271 |
proto_binary_fetched_int24 | 105 |
proto_binary_fetched_bigint | 761 |
proto_binary_fetched_decimal | 30 |
proto_binary_fetched_json | 584 |
proto_binary_fetched_blob | 268 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 248531 |
