Run Time: 0.000620
Run Time: 0.000189
WHERE (`xf_thread`.`thread_id` = '45634')
Run Time: 0.001131
WHERE (`xf_post`.`thread_id` = 45634) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003204
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 20 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (769150, 769183, 769189, 769191, 770188))
Run Time: 0.001788
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 24 | Using index condition; Using filesort |
Params: 45634
Run Time: 0.000093
Params: 0, ڜ#
Run Time: 0.000138
Params: ڜ#, XF\Pub\Controller\Thread, Index, valid, thread_id=45634, 1714876913, , 0, ڜ#
Run Time: 0.000119
WHERE (`xf_session_activity`.`user_id` = 46690) AND (`xf_session_activity`.`unique_key` = '46690')
Run Time: 0.000167
WHERE (`xf_thread_reply_ban`.`thread_id` = 45634) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000239
Run Time: 0.000210
bytes_sent | 12368 |
bytes_received | 369333 |
packets_sent | 124 |
packets_received | 1108 |
protocol_overhead_in | 4432 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 296532 |
packets_sent_command | 61 |
packets_received_change_user | 128 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 110 |
rows_buffered_from_client_ps | 110 |
rows_skipped_ps | 110 |
proto_binary_fetched_bit | 1684 |
proto_binary_fetched_short | 417 |
proto_binary_fetched_bigint | 1278 |
proto_binary_fetched_decimal | 48 |
proto_binary_fetched_json | 787 |
proto_binary_fetched_blob | 357 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 293918 |
