Run Time: 0.000732
Run Time: 0.000268
WHERE (`xf_thread`.`thread_id` = '22683')
Run Time: 0.000565
WHERE (`xf_post`.`thread_id` = 22683) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002937
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 14 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (304948, 305041, 305529))
Run Time: 0.001650
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 6 | Using index condition; Using filesort |
Params: 22683
Run Time: 0.000087
Params: 0, Y
Run Time: 0.000132
Params: Y, XF\Pub\Controller\Thread, Index, valid, thread_id=22683, 1714772234, , 0, Y
Run Time: 0.000148
WHERE (`xf_session_activity`.`user_id` = 11339) AND (`xf_session_activity`.`unique_key` = '11339')
Run Time: 0.000163
WHERE (`xf_thread_reply_ban`.`thread_id` = 22683) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000191
Run Time: 0.000175
bytes_sent | 12336 |
bytes_received | 320004 |
packets_sent | 124 |
packets_received | 1084 |
protocol_overhead_in | 4336 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 247203 |
packets_sent_command | 61 |
packets_received_change_user | 104 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 86 |
rows_buffered_from_client_ps | 86 |
rows_skipped_ps | 86 |
proto_binary_fetched_bit | 546 |
proto_binary_fetched_short | 269 |
proto_binary_fetched_int24 | 105 |
proto_binary_fetched_bigint | 760 |
proto_binary_fetched_decimal | 30 |
proto_binary_fetched_json | 577 |
proto_binary_fetched_blob | 265 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 245365 |
