Run Time: 0.000639
Run Time: 0.000213
WHERE (`xf_thread`.`thread_id` = '1701')
Run Time: 0.001011
WHERE (`xf_post`.`thread_id` = 1701) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001771
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 1 | Using where; Using filesort |
Params: 1701
Run Time: 0.000093
Params: 0,
Run Time: 0.000165
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=1701, 1714669008, , 0,
Run Time: 0.000108
WHERE (`xf_session_activity`.`user_id` = 1) AND (`xf_session_activity`.`unique_key` = '1')
Run Time: 0.000192
Run Time: 0.000246
bytes_sent | 9329 |
bytes_received | 225974 |
packets_sent | 100 |
packets_received | 821 |
protocol_overhead_in | 3284 |
protocol_overhead_out | 400 |
bytes_received_rset_header_packet | 306 |
bytes_received_rset_row_packet | 114 |
bytes_received_prepare_response_packet | 51818 |
bytes_received_change_user_packet | 173306 |
packets_sent_command | 49 |
packets_received_rset_header | 34 |
packets_received_rset_row | 18 |
packets_received_prepare_response | 676 |
packets_received_change_user | 75 |
result_set_queries | 14 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 15 |
rows_fetched_from_server_ps | 61 |
rows_buffered_from_client_ps | 61 |
rows_skipped_ps | 61 |
proto_binary_fetched_bit | 25 |
proto_binary_fetched_short | 36 |
proto_binary_fetched_int24 | 14 |
proto_binary_fetched_bigint | 104 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 241 |
proto_binary_fetched_blob | 67 |
com_stmt_prepare | 16 |
com_stmt_execute | 16 |
com_stmt_close | 15 |
bytes_received_real_data_ps | 172474 |
