Run Time: 0.000440
Run Time: 0.000242
WHERE (`xf_thread`.`thread_id` = '2683')
Run Time: 0.000803
WHERE (`xf_post`.`thread_id` = 2683) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002179
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 9 | Using where; Using filesort |
Params: 2683
Run Time: 0.000087
Params: 0,
Run Time: 0.000159
WHERE (`xf_session_activity`.`user_id` = 1061) AND (`xf_session_activity`.`unique_key` = '1061')
Run Time: 0.000195
Run Time: 0.000299
bytes_sent | 8933 |
bytes_received | 268539 |
packets_sent | 94 |
packets_received | 817 |
protocol_overhead_in | 3268 |
protocol_overhead_out | 376 |
bytes_received_rset_header_packet | 297 |
bytes_received_rset_row_packet | 103 |
bytes_received_prepare_response_packet | 51575 |
bytes_received_change_user_packet | 216150 |
packets_sent_command | 46 |
packets_received_rset_header | 33 |
packets_received_rset_row | 17 |
packets_received_prepare_response | 667 |
packets_received_change_user | 83 |
result_set_queries | 14 |
non_result_set_queries | 3 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 14 |
rows_fetched_from_server_ps | 69 |
rows_buffered_from_client_ps | 69 |
rows_skipped_ps | 69 |
proto_binary_fetched_bit | 121 |
proto_binary_fetched_short | 172 |
proto_binary_fetched_int24 | 70 |
proto_binary_fetched_bigint | 456 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 401 |
proto_binary_fetched_blob | 187 |
com_stmt_prepare | 15 |
com_stmt_execute | 15 |
com_stmt_close | 14 |
bytes_received_real_data_ps | 214850 |
